Results 1 to 10 of 17
Thread: Series door vents
    Oct 2014
    Northern NSW.Australia
    Series door vents
    Hi,
    Just seen a video, with low front door vents, on a S3.
    Anyone shed any light please.
    Good for getting air around the foot panels.
    Thanks.
    whitehillbilly
    May 2008
    Bundaberg Qld
    Best guess would be an aftermarket fit although they were factory fit in some early Rover cars (my 48 P3 has them).
    I have seen them, but only rarely. They are not a factory item or an accessory special to Landrovers. In my view, a very poor idea, because they direct the plume of dust from the front wheel into the cab. The ones on early Patrols did exactly that. The ones on early Landcruisers were slightly better because they were partly shielded from the dudt plume by the front mudguards.
    I suggest that they might be acceptable in humid areas where dust is uncommon, or when only used on bitumen, otherwise, not much use.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i have them in the doors on madge but a previous owner flatterned them and put door cards on...
    i havent been able to find a replacement tho it has to be said i havent tried to hard either
    be interested to see any that are available...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Narre Warren South
    There was a similar thread recently, I found that truck component suppliers have them but they may be on the large side.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2008
    Bundaberg Qld
    Jul 2012
    Opposite intention
    Hello from Brisbane.
    Those caravan vents are typically installed towards the front of the roof to keep dust out as they are moving along a road. We tended to close them on dirt roads plus had special covers on the fridge and door ventilators to seal the interior.
    I had thought of installing some kind of vent arrangement between my roof panel and safari panel but clearance is an issue. The rotary type that were fitted to mini vans and Escort vans might have had a lower profile. However, I may simply leave well enough alone or get new door tops with the dual sliding panels.
    Neil
    1975 S3 88" - Ratel
    May 2008
    Bundaberg Qld
    Neil,
    IIRC, there are factory vents that are fitted between the roof and safari panel. I think my S3 has 4 of them.
    Oct 2014
    Thanks for the replies and comments.
    whitehillbilly
    Yes. At least some of the tropical roofs have bulges for them.
