Results 1 to 6 of 6
Thread: Rear Damper top nut
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Rear Damper top nut
    Looking for a noise in the rear suspension of the County today, found the nuts on the top of both rear dampers were about a turn loose. To save removing one to see what size and thread they are, does anyone know off hand? (I want to fit new self locking nuts)
    Mar 2007
    Canada
    M12.
    You can figure it out from the part number. NY112041L. The "12" in the middle is the size. Or you could Google the part number...
    Jun 2016
    I just recently replaced the rear shocks on my "95 110. I assumed the top nut and the nut that came with the Bilsteins were the same. Nope, only after getting the top nut on a turn and bit did I realize. I'm pretty sure the top bracket is 12 x 1.5 and the shock stock was 12 x 1.25
    Rick
    Jul 2008
    I agree. I've had a few different shocks on my County over the years some are M12 Course, but some have been M12 Fine.
    If you work with nuts a bit you can easily see the difference.
    Clive
    Jun 2016
    John, I hope I didn't give you a bum steer. I just checked and the top nut is 12 x 1.75 on mine.
    Rick
    JDNSW's Avatar
    I haven't got the replacements yet. But it sounds like I might do well to pull a nut off and measure the pitch!
