Hi all,
My turn to ask a question. I’ve noticed, radio or Bluetooth to my iPhone (via tune2air) that on random occasions my left hand audio control switches function. Volume up becomes volume down, mode becomes volume up, volume down becomes mode. Has anyone had a similar issue and know a fix please?
Jeff
2007 Audi RS4 (B7)
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
My 2010 model has had the same problem for a few years now. Doesn't usually affect the cruise control but the radio volume in particular doesn't work. Always fixes itself on a restart. I just live with it as it is no big deal to use the volume knob on the radio.
Occasionally the cruise up down buttons go haywire (much rarer) and that is usually fixed by turning cruise off and then back on again.
I think they are software glitches but it could also be a mechanical problem with the connections causing the software problem.
Bob
2007 Audi RS4 (B7)
The power of google found me this thread. I'll give it a try FWIW.
steering wheel radio control button fault
2007 Audi RS4 (B7)
I had the same intermittent problems with my MY09 D4, caused by poor contact in the connector on the loom from the switches. A little contact cleaner sprayed into the socket overcame the fault.
My09 D4 used to have issues too due to connector issues. Remove the airbag, clean and reseat the connector.
Awesome guys. Seems too simple a fix but evidence is there so tomorrow contact cleaner and disassembly is on the cards![]()
2007 Audi RS4 (B7)
Mine recently started playing up so will give the re-seat of the plugs a go and clean with contact cleaner.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Mine hasn’t played up since, 6 years later.
2007 Audi RS4 (B7)
