Results 1 to 8 of 8
Thread: Fuel Strainer on Fuel Pick- up Pipe
    Jul 2009
    S.E.Qld
    Can anybody give me some advice on how to cut and solder a new fuel strainer at the end of the pick-up pipe in the tank? I would like to get it right first time as I'm a bit short on material. I bought a square foot of material about 10 years ago and put it in a safe place. You know the rest. However I managed to acquire another small piece, just enough for one pipe. I have been using an inline filter at the end of the pipe for a number of years. I would like to hear from someone that has actually done it. Thank you. .W.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    I have done a few
    I no longer bother as fuel these days seems to eat them
    The bottom line is you need to prepare properly
    Cut your mesh and tin the edges you are going to solder. Use lots of soldering fluid and clean well afterwards
    I found that the tube was very hard to tin correctly
    Once everything you need tinned is done you shape it and solder the seams using just enough heat to get the solder fluid
    Clean up well and you should be on a winner
    Hope it helps
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jul 2009
    S.E.Qld
    Thank you for your excellent instructions. Did you solder in a separate bottom, or just shape the gauze like a bag ? .W.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by B.S.F. View Post
    like a bag
    Jan 2017
    Geraldton WA
    Maybe something like this would be the easiest option here
    New *OEM QUALITY* Fuel Pump Strainer For Subaru Impreza WRX STi G11 2.0L Turbo | eBay
    4.6m Quintrex boat
    Perhaps - except I'm not sure how you would get it through the hole in the top of the tank - it is only about 20mm across.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    yeah that kills a lot of options
    i found nylon units with the right ID (8mm from memory) and they were 19mm OD by 38mm long from memory
    i fitted them from the drain bung as they slid up firmly but easily..
    got lots of filter area that way...
    but they came from the US of A
    but they work great!
    Jul 2009
    S.E.Qld
    Thank you . No problem. It's for a Series 1 one tank. I can easily get my hand and arm inside. .W.
