Pretty sure there's a o-ring in the fitting you dismantled unless someone's modified it.
Vehicle TDI300 Ser1 disco
Under the left hand side of the radiator, the two tubes that carry the ATF to the cooler one has a join in it with approx 20 mm. connections joins in it . Does the join have an O ring in it mine is leaking Today I undid the join as far as I could and cleaned and wrapped it with thread tape then did the join back up hope fully it has stopped
Hodgo
Orings at either end but at if its leaking near a crimp then its new hose time.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
