Results 1 to 10 of 15
Thread: Thoughts on 200tdi
    Oct 2014
    Thoughts on 200tdi
    Hi everyone. I've been on the lookout to buy a defender. Im after a 200 or 300tdi. There is a 92 200tdi for sale that looks to be in fairly good condition but it does have 400,000kms so i guess its quite possible it could be up for a rebuild in the time that i own it. My question is how difficult is it getting parts for the 200tdi now? And how much would i be looking at to have it rebuilt? Should i be worried about parts availability and look for a 300tdi instead?
    Free Again Thanks Dan
    Quote Originally Posted by MJA View Post
    Cylinder heads for the 200tdi are about as rare as hens teeth
    If it was me id look for a 300 tdi parts are abundant and cheaper in my opinion
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by rangieman View Post
    you use a 300tdi head and pistons in the 200tdi if it need a rebuild i am told. never done it myself but it sounds feasible.
    but yeah, i agree because 300tdi are easier to maintain in the long run, timing belt wise etc etc
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor View Post
    Have heard the same but a lot of work and expense for a normally easily and cheaper exercise .
    I guess it depend`s how much you love the car or want it
    Jan 2010
    Timing belt etc etc? Not sure what all thats about?
    Difficulty finding parts would kick in if you crack the cylinder head. I have a 200tdi and 300tdi. Servicing is near enough the same in regards to cost and difficulty. I dont prefer working on one over the other.
    The 200tdi has proved to be more robust and when mine is due I will get a rebuild.
    Im heading up to 600k and I have changed the CH (coolant leak lead to overheat) a few years back with a reconditioned one sourced from turners uk - its not impossible to find servicable heads but could take a month or two to deliver.
    You can rebuild a 200tdi with a 300tdi top end or swap the whole thing out for a lower k 300.
    Dont rule out the 200. If it doesnt smoke, knock, use oil or coolant, and the oil cap can be placed upside down without being blown off you may have a motor thats good for another 200k+ before rebuild. If you can, get it compression tested.
    If you do buy it, or any TDI, install a low coolant alarm!
    The 200 tdi is a more robust engine than the 300tdi.
    I had a 200tdi in a Disco with 450,000 on it and ran sweet. I like the 200tdis over the 300’s
    I used to compete in winch challenges with a Defender 90 with a 200tdi and never let me down and I gave it hell.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Oct 2017
    Phillip Island
    Hi first post here on returning to the LR scene. Take a look at the 3.9 Isuzu County. I almost bought a 200 Tdi Disco but held off for a County and just picked one up. From what I've heard and read the 3.9 is a little more forgiving than the 200Tdi. In terms of performance it feels slightly quicker off the mark than the 200 Tdi. On the 500km drive home it returned 10l/100km. Certainly noisier than the Tdi but I look at it as character. The Isuzu has mountains more torque off the mark. I'm not a guru, these are just my opinions based on back to back test runs
    Jan 2010
    200tdi vs 3.9 NA/Turbo. Thats a whole other thread
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by manic View Post
    many mechanics i have spoken to say the 300tdi is much easier and quicker to do timing belts and front of engine work on..
    JC included...
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by Zcoota View Post
    yep
    one is a revs based power unit the other is a torque based unit
    owned 300tdi 2 door 110 and a 4bd1T county at the same time and if i was towing a double horse float or a large van i would pick the 4bd1T otherwise i much prefer the 300/200tdi power plant.
    both have pluses and minuses for sure
    both are useless into a big head wind tho it has to be said esp if there is a slight incline anywhere to be seen
