Results 1 to 6 of 6
Thread: Blowing fuse when key is in on position
    Sep 2017
    New Norfolk
    Hi all. Driving home the other day. George stops dead. No warning or spluttering. Just off and coasting. Discovered the fuse, engine with lightning bolt, 10amp I think, has blown. Replaced fuse but as soon as ignition turned to on position the fuse blows out. Car cranks over fine. New battery. Was going to put a 200amp fuse in to teach him a lesson but decided to give him a chance first. Any ideas? Thanks in advance.
    Yeah.. find the short! Blowing fuse when key is in on position
    Crafers West South Australia
    Wire a 100W or bigger lamp or globe across the fuse terminals, turn on the ignition and start wriggling things. When the light goes out you're in the right area!
    Sep 2017
    New Norfolk
    Thanks bee utey. I’ll give it a go.
    BigBlackDog Guest
    That's a lot of amps. It must be somewhere between the fuse, the rally that switches that circuit and whatever the load is for that circuit, I think. Disconnect battery, get a multimeter on resistance, one end to solid earth other end on a long lead and a probe, start poking in the fuse holder and wiggling stuff to see if you can get the meter to go from no resistance (fuse blows) to all the resistance (fuse won't blow)
    good luck try not to fry your battery!
    May 2009
    West Gippsland - Victoria
    X2
    What bee utey says though perhaps you mightn't need a lamp this big . For something simple have a look see if the fuel stop solenoid wire has fallen off and is framing to the vehicle ?
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
