Results 1 to 8 of 8
Thread: Up the Cape
    May 2015
    MoveLater2 Up the Cape
    I am thinking of taking my 2009 D3 up to the Cape next year. I have made a set of drawers for the back and will be using a rooftop tent.
    I plan on buying a winch, redoing the door seals, a bra and protector for the air compressor for the suspension. I already have skid pan, recovery gear and a few spares in my kit.
    Any advice on the mechanical side that I should do would be appreciated.
    Back down the hill.
    Take the usual hoses, belts and a couple of tyres etc. You won't need the winch or recovery gear, these days it's no longer a frontier.
    If you have any mechanical issues up there, these blokes are good.
    Hyper Tune British Motors Land Rover - Home
    Mandurah WA
    If you have not already done so,fit a manual release cable to the tailgate.If the actuator fails with the upper tailgate shut,it is a very awkward job opening it especially if you have drawers fitted.An easy job when tailgate open....remove plastic trim & then carpeted trim lower gate........prise up the moisture shield.......remove latch.......drill hole in operating lever.......attach trace wire and run a loop to under the plastic trim.......replace everything.....job's done.
    Back down the hill.
    If you're a customer of MR, I believe they'll give you an emergency kit to take with you. You give it back upon your return, only paying for what you have used.
    May 2015
    I am so I will ask into that.
    May 2015
    Quote Originally Posted by eddy View Post
    Very handy tip. I will do just that. Thanks.
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by forwari View Post
    This thread has lots of detail and a few options for you:
    Manual tailgate release D3
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    LRD414's Avatar
    Oct 2014
    Lower control arm bushes are worth checking and replacing if worn.
    If you haven't seen this thread it's worth a read:
    Essential D3 D4 RRS travelling spares
