Results 1 to 10 of 12
Thread: Conver Coil to Air?
    May 2015
    Williamstown, Victoria
    Conver Coil to Air?
    Hello, I'd guess it is do able. Has any one done this?I'm looking at a manual coil sprung d3
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    NSW SW Slopes
    All the wiring harnesses will be missing the wiring so unless a donor vehicle is available to rob for virtually all the wiring then IMO not practical to convert.
    Jul 2013
    Could be doable with factory air struts and aftermarket controllers?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by shanegtr View Post
    You could probably do a really good custom set up using factory airbags and the rest aftermarket negating finding the original wiring looms and ecu etc.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Bangor, NSW
    There are also legal/ADR considerations: if the vehicle didn't come with factory air suspension, the controls to alter height are not allowed to be accessible from the driver's seat. I'm guessing to stop low-rider-style bouncing, etc.
    Brisbane, Queensland
    The D3S without EAS also missed out on TR. I remember it had traction control switches similar to the early L322.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by jonesy63 View Post
    Plenty of vehicles with after market air bags fitted.
    1974 VW Kombi bus
    Mar 2012
    Gabbadah WA
    Can you just fit the air struts and have an air line to each , and normal tyre valves to a good access spot , the same as aftermarket airbags fitted to cars etc . ?
    NSW SW Slopes
    Yes, but then no ability to adjust the ride height on the fly nor cross axle articulation although the latter only requires a solenoid at front and rear to achieve.
    Quote Originally Posted by Bohica View Post
    Julian
    Just buy a air sprung D3 - far more than coils around and then no conversion hassles.
