 Fossicker
						Supporter
						Fossicker
						SupporterHi Guys,
Has anyone put an auxiliary battery in behind the lining in the boot of an L320? Im trying to keep it out of the engine bay to reduce heat damage.
Chris
L320 TDV6 3.0
105K, GOE Rods, IID BT Tool, Rhino Platform Rack, 255/55r19 Maxxis 980 AT
D2 TD5
255K, BFG All Terrains, Chipped, 1 inch lift King Springs, TJM Full Rack
Hi Woody, there is no problem with fitting the auxiliary battery in the engine bay, on a tray, just in front of the cranking battery, unless you have the air box there.
In that case, you can, with a bit of rearranging, you can fit it in the battery box on the other side.
