Thread: Whoops
    Oct 2013
    Ballarat
    Whoops
    My wife heading away on a trip went to fill up ... Whoops 20 liters of ULP into the tank tank was nearly empty ...
    bugga luckily she rang me and asked "what do I do ?'
    Dont start it dont move it rang my indi and asked what now...
    After his suggestion flat top home armed with empty drums and a long length of hose undid the filler into the tank and drained out the 30 lites then connected it up put in another 20 litres drained that , connected it up and filled the tank
    300 km later all good ......at the moment
    Did the same thing many years ago , a bunch of use were going up the Gulf barra fishing. We stopped in at Broken hill for fuel I started filling up my mates diesel 80 series Landcruiser with unleaded put 20 litres in before I realised. It was a 90litre tank. One of the blokes with us was a diesel mechanic he said just fill it up with diesel he said they used to do it all the time too clean the system out. So we did. Drove off without a problem wouldnt even know that there was ulp in it. That motor did over 400,000klms after this happened and was sold with the same motor in it. I dont advocate to try this but this was our experience
    Sep 2009
    Quote Originally Posted by Tinman View Post
    80 series diesel engine isn't a CRD, but a primitive design (indirect injection, mechanical injectors, lower pressure fuel lines compared to today's engines). Definitely don't do this in a modern diesel as you will seriously damage it.
    Jul 2010
    Hunter Valley NSW
    Anyone had the pleasure of using this gadget I found in the floor jack compartment recently
    Land Rover Discovery 4 misfueling device explained - YouTube
    Dec 2011
    Adelaide
    142.79 MB
    Cool
    Quote Originally Posted by northiam View Post
    I went looking for this, but couldn't find it - then I realised why!!
    Mine is a petrol :<0
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Bunbury, WA
    I had to use it several times on a recent desert trip. There was one servo that obviously had a ULP nozzle on their diesel pump so it would trigger every time I filled up. Also filling using jerry cans would trigger it. Got quite good at "insert, engage, twist and pull" by the end....
    Chris
    Brisbane,some of the time.
    Yes used it a few times as well,mainly after filling from jerries.
    It did trip once by itself after spending a day near Finke driving on really bad corrogations
    Oct 2013
    Ballarat
    My car has a long range tank fitted so they have modified the filler so you can fill the both tanks from the normal inlet ,good part can use hi flow nozzle to fill the tank . now what to do with 40 litres of contaminated fuel ?
    Mar 2016
    I fill my normal tank with a high flow nozzle. You simply put it in the / near the throat and pull the trigger? Full flow fill? I don’t understand the issue personally. Just because it doesn’t insert deep into the throat of the filler, doesn’t change anything
    2007 Audi RS4 (B7)
    Oct 2012
    Whoops
    Quote Originally Posted by crawal View Post
    Run it through an outboard motor or lawn mower etc. Any petrol motor won’t mind quite a bit of diesel. Two strokes run an oily mix in any case.
    I accidentally filled my small generator with 100% diesel and it took quite a bit of flushing to get it to fire again. Smoke was impressive.
