For that amount I would expect the case sleeved for the inter shaft a new TBD new bearings and seals and an extended sump
AM
Hi Guys,
Long time listener, first time caller!
Last month I was 'fortunate' enough to purchase a 2004 Defender 110 with 85k on the clock from a fella in NSW (I live up in Middlemount, Central QLD). This is my first Defender; not only to own, but to sit in as well! To be honest, I don't mind the 'ol brit, but I do think I have been kicked out of every LC online club in AU! Oh well.
Worry not, my first post does have a point! Part of my 'agreement' with the handbrake was to have the car mechanically checked etc. no problems, and he passed no problems. Now.... have noticed the following; Oil leaking out of rocket cover, cooling system leaking from a few hoses, the transfer cast leaking, squeaking belts, I have just dropped off the car in Mackay to the Land Rover place up there. The very knowledgeable fella there has stated that there was a design fault that causes all 110's to leak at the transfer case, and has suggest an approx. $2500 rebuild using 'glue' to stop the leak?! What are your thoughts?
Do you guys think the above problems, are going to bankrupt me?
Rhys.
 Wizard
						Wizard
AM
 Swaggie
						Subscriber
						Swaggie
						SubscriberI would be surprised if at 85KK that the transfer case hole for the intermediate shaft would need resleeving.
My D2 had a leak there which was wetting the handbrake so I had it done with a new Oring and some epoxy "glue" .
The total cost drive in drive out was $700.
Mine has now done about 40Kk on the repair and it is still oil tight, although I guess at some stage it will leak again and then may need resleeving as the car has now done 190Kk.
So I think the bloke may be having a lend.
Regards Philip A
Wow 2500!!??
I might move to qld...😞
Jc
Whoops, 185K on the clock!
