Results 1 to 10 of 27
Thread: Toro or Kawasaki Powered Zero Turn Mower
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Toro offers two engines between both models of their 42 inch deck and their 50 inch deck in their zero turn mowers this year. The SS and the MX 42 inch deck both feature the 24.5 hp Toro motor. The "Commercial" range in the 50 inch deck features a Kawasaki motor.
    Which of the two engines; the Toro or the Kawasaki is the most reliable? Also, more economical to get engine parts for?
    While discussing zero turn mowers, has anyone compared between a Toro and something like the Hustler Raptor ? Which of the two mowers is the more reliable?
    Kind Regards
    Lionel
    May 2009
    West Gippsland - Victoria
    Before you think of buying anything Toro have a very close look at their spare parts prices and availability.
    I nearly got caught on this hook a couple of years ago trying to source a simple ignition coil for a second hand Toro ride on mower. No 'non genuine' spares available as Toro had the market all stitched up and the Toro spares were eye watering expensive in Australia and US agents were 'unwilling' or precluded from selling overseas.
    Better IMO to buy from a less 'aggressive' company.
    The John Deere ride on mower I bought over 20 years ago with Kawasaki engine and transmission is still going strong and its had a hard though well maintained life. BTW John Deere spare parts prices are much, much cheaper and more readily available in Australia than Toro parts.
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    Irymple, Victoria, Australia
    I would opt for the Kwaka engine.
    Most of our small motors here are all Honda and they always seem to start first pull and run trouble free
    and I am sure a Kwaka engine would serve you much the same.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Jan 2015
    Brisbane, QLD
    My folks own a macadamia plantation- they use a toro zero turn as one of their mini harvesters. The toro uses a Kubota engine. they also have 2 other mowers and a bobcat running similar kubota engines. As far as reliability, they haven’t had any issues, and the machines get a rough workout running 10-12 hrs days for weeks on end.
    Don’t have much info on the cutting decks as their deck was removed for the harvester adaption.
    Might be worth a call to some suppliers in orchard/plantation area rearts etc. they are near Lismore and use a place called ongmac trading. Hope it helps.
    Josh
    Cheers, Josh
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Thanks for the replies.
    Funny thing about the Toro is that a couple of years ago they had an option of a 42 inch deck or a 50 inch deck - both were powered by a Kawasaki motor. This year the bog standard SS and the Industrial MX in the 42 are both fitted with "Toro" motors. It is not until the 50 inch mower that they have a Kawasaki motor fitted. Makes you wonder why a difference of 8 inches means the Toro motor is not used any more?
    I have had a lend of a friend's one or two year old Toro 42 inch. It is the model that came fitted with the Kawasaki motor. I have used the Toro for a couple of days mowing long grass; in the meantime I have been reading reviews. I then checked out my local Hustler dealer on Friday. The Hustler Raptor 42 inch does come with a Kawasaki motor fitted as standard.
    As a comparison between the Toro I have been using and the Hustler - it is easy to see that the Hustler has a more robust frame. Dearer too of course. The Raptor SD has a transfer case that is not sealed, so it actually be serviced. The lower model Raptor has a sealed transfer case and is not serviceable. Looks like I will be saving my pennies until the end of this month to get up to matching the cost of the Hustler Raptor SD. Damn mower will be dearer to buy than my current daily driver Commodore was!
    Kind Regards
    Lionel
    Shepparton
    A mate runs a lawn mower business - he uses Hustlers.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    If you go the Toro, go the Kwaka. I used one in a commercial application for several years and it was great, but Toro parts are expensive.
    The Hustler is the go IMO - more robust and there's a reason a LOT of professionals and councils, contractors, etc use them.
    Mar 2010
    Queensland
    12.97 MB
    Hello Homestar, Crash, Mick88, DeanoH & JR1
    Thank you for all your replies - much appreciated.
    Yes Hustler will be the one that I will aim for - the SD. The SD is the more industrial version of the two styles in 42 inch cut. It is more accessible for servicing. It will just take a bit longer to meet the cost.
    All the grass has been cut for now anyway, using a friend's Toro 42 inch deck with a Kawasaki engine fitted to it - so getting control of the grass was the first priority; and it has been tucked away. The grass was long and the Kawasaki engine powered through it.
    Kind Regards
    Lionel
    99.87 MB
    Quote Originally Posted by DeanoH View Post
    Deano
    I agree. My John Deere has the 25hp Kwaka with a 54" deck and things are rough here! In the last 6 or 7 years it hasn't had or needed anything other than the standard off the shelf DIY JD service kit which is not expensive and contains everything.
    Slunnie
    Narre Warren South
    Lionel,
    Do you have a spare Land Rover rear axle ? If so you could make one of these .....
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
