I have a 2.7TDV6 L320 - series 1.
If I was to buy another L320 I would go the Series 2 update with the 3.6TDV8 but you will be pushed to find one as they were not sold for too long.  Failing that the TDV6 which is the 3.0 in that model - it only has a little less power and torque than the TDV8 but the TDV8 sounds oh so good.
The basic specification is linked to the engine - basic is TDV6, next is TDV8 and highest is the Supercharged Petrol V8 - you will need to research the different spec levels - not necessarily the same as the equivalent D4 - also our specs are different to Uk specs so research AU sites.
Also remember you will need to consider your usage - the D4 is 7" longer in the wheelbase than the RRS and is a lot more boxier - the rear of the RRS slopes so you loose a bit of higher cargo area space.  The RRS dash is sloped so feels a bit more comfortable that the very upright Disco dash - the Disco has more sockets etc.
So really it comes down to what you need - I just have me and the RRS is fine - if I had a family with a few rug rats and lots of camping gear then the Disco would be more suitable.
Hope this helps.
