Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: Giandel Pure Sine Wave Inverters
    Kallangur, Brisbane
    MoveLater2 Giandel Pure Sine Wave Inverters
    Has anyone had experience with this brand of inverter?
    I am looking at a 3300/6600W version to power my caravan when off grid. Large Shell Pure Sine Wave Power Inverter 3300W/6600W 12V-240V+Remote Controller | eBay
    I like the fact that the 12V terminals have a stud & hex nut type connection rather than a knurled nut which would be finger tightened.
    The inverter is no doubt a re-branded generic chinese made inverter but hopefully with some Australian standards input.
    The unit is supplied from an Australian address.
    The rating is much larger than I actually need but I figured that bigger is cooler. Battery power will be from 360Ah of LifePo4.
    + 2016 D4 TDV6
    May 2009
    West Gippsland - Victoria
    Interesting reading the 'blurb' where it says ............... can be overloaded to 3300 watt ............... as well as continuous output power 3300 watt.
    This translates to a 12 volt battery current of 275 amps and if the claimed surge power delivery of 6600 watts is to be believed then over 500 amps. By the look of the provided battery cables they would surely end up as a melted mess if used for the 'intended purpose', so I'd be a bit wary about the whole unit.
    What sort of power loading do you intend using this inverter for ?
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    Kallangur, Brisbane
    Thanks for your thoughts Deano, hence why I asked the question. I am also sceptical about these sorts of devices at theses sorts of prices. A reputable brand like Victron would be 8 or 10 times the price for the same spec.
    I will be running toaster/microwave/fans/PC's & occasionally the aircon (if it will start it) so 12V/150A would be the maximum continuous draw. I am under no illusions about the cabling supplied & will change it for something suitable like 25mm2 battery cable or tri rated switchboard cable.
    There is always ebay's dispute process if it fails to meet expectations i suppose.
    Rory
    + 2016 D4 TDV6
    Jan 2017
    Geraldton WA
    360AH is a Lot of stored power But an air con and occasional use of the toaster/Microwave will eat that energy up pretty quickly.
    I have a similar inverter (2000w) and it powers my small inverter stick welder and microwave that I take away on trips easily But I haven't used it continuously for any length of time so I don't know if it can handle a continues draw of high ampage use.
    I only paid $150-$200 for the inverter and for what I use it for I find it to be great value for money.
    I am interested to see how yours performs $335.99 is Not a huge outlay so I think that I is probably worth giving this a go.
    4.6m Quintrex boat
    May 2012
    Wannanup WA
    4.70 MB
    Any wattage calculations you do need to be x 1.2, or add 20% at a minimum. They are also very inefficient at low loads and will probably draw a lot more than you realise.
    I would not even attempt to run an air conditioner off a unit of that size.
    Intermittent use of a toaster and / or microwave would probably be ok, but make sure the inverter is operated in a well ventilated cool place.
    These things also need a good ground wire. They put out a lethal voltage just the same as the mains.
    Aug 2010
    Sunbury, VIC
    Based on the output versus price is will be just like any other cheap Chinese inverter - it should work fine for as long as it works.
    If you've lashed out on a 360Ah battery why scimp on a crappy inverter? A good one that's capable of 3000 watts would be $1,500 plus but you get what you pay for.
    I've got an Aussie made Selectronic unit but I don't think they make them any more - but worth looking for a second hand one - they are bullet proof but very large and heavy compared to the cheap versions.
    My 600 watt unit (peaks at 1,500 watt for 2 minutes) were going for near $1000 new, years ago but I snagged mine second hand for $400. Has an auto sleep mode so doesn't draw power when not in use which inverters do - a unit like that would draw around 2 amps sitting there doing nothing.
    Also, most cheap units aren't suitable to hard wire into an isolated power system like a caravan as the neutral can't be earthed without damaging the unit usually.
    May 2012
    Adelaide Hills, SA
    Good stuff for Chinese
    Hi, I am using a 2800 - 5600 Giandel Pure Sine Wave inverter in the caravan.
    I have about 250 Watts of solar panels, 2 X 100 AH Lead Crystal batteries (real good things from Traxide).
    I can run the roof top air conditioner for at least two hours (haven't tried longer).
    The inverter is mounted under a seat in the caravan so the wired remote is handy, just ran the wire to a suitable available spot to turn it on and off.
    It was supplied with twin wiring to carry the load but I went to an auto electrician and had heavy right length cables made to suit.
    I'm happy with the unit, I considered a 2800 was plenty big enough with the 5600 kicker on air con start up. Incidentally, they recommend to turn the load on first and the inverter does a soft start.
    Mike
    Oh as per another post on here, these have an external earthing post so they can be made safe.
    Last edited by nismine01; 5th November 2017 at 03:36 PM. Reason: Added information
    May 2012
    Adelaide Hills, SA
    It's value for money Homestar
    At $269 for my 2800 vs your over $1500 I look at it like this.
    Mine only lasts, say three years and yours lasts fifteen years, I'm in front, mine cost less that $100 a year yours cost $100 a year.
    Now if mine lasts five years I'm miles in front value wise, as I have one of these Giandels I can tell you they are not 'crappy' as you suggest.
    When Japanese cars first came on the market they were sneered at.
    When Korean cars first came on the market they were sneered at, both with good reason but we don't sneer at them now.
    I really wish I could buy Australian but until they, or we, become price competitive unfortunately it aint going to happen.
    Tindel Solar here in SA have done it, better quality than any where else and at equal or better pricing, the other companies just have to catch up.
    Having said that we are all driving imported vehicles, Land Rovers.
    Mike
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by nismine01 View Post
    Mike
    But is the Neutral at earth potential? Just earthing it isn't enough...
    To be used safely in a caravan either the electronics need to hold the neutral conductor close to earth potential or the neutral itself needs to be earthed - which will kill some inverters.
    Not saying those aren't big most Chinese units aren't the best is all.
    Aug 2010
    Sunbury, VIC
    Mike
    But is it SAFE! That's the point I'm trying to make - cheap inverters usually aren't designed to be permanently installed in vans like this.
    No good being in front if your dead...
    Also, nothing like a good camping weekend being ruined when the inverter dies on the first night your away.
    Again, not saying these aren't safe, just trying to get across the safety aspects here - I work with isolated power supplies for a living is all, without knowing the electrical details of the unit I wouldn't be making it a part of a fixed wiring installation.
    I've said enough - you'll either check into this or not give a **** and blindly but one - no skin off my back, but the OP asked for advice and I offered some.
    What you choose to do with it is your concern.
    Chinese versus other countries has been done to death - some of it's good, some of it's ****, working out the difference can be the hard bit but if it looks like a duck and quacks like a duck...
    Oh, and an RCD won't save you if the inverter isn't right for the application and fails either, but I'm not going into fault paths here and what an RCD is and isn't good for if you don't understand the basics.
    You're call...
