Results 1 to 3 of 3
Thread: Roller Door Side Track
    Jul 2009
    S.E.Qld
    I have to replace a roller door side track. Are they standard items or has every door manufacturer their own? My door is about 15 years old and was made by Creek Metal Ind.in Vic. I'm in Qld. Any idea where I can buy a track in the greater Brisbane area? Thank you. .W.
    Dec 2008
    Tewantin, Qld
    We supply B&D roller doors with our sheds.
    Tracks profile looks pretty much the same as yours. Track dims are 27mm wide and 25mm deep. Overall width is 40mm
    The B&D units have brackets and stops welded along the length of theirs though.
    Assuming is less than 3m long, you should be able to get a sheet metal guy to fold that up.
    Cheer Glen
    Jul 2009
    S.E.Qld
    Thank you for your reply. I did manage to straighten it. I found a piece of heavy steel exactly the right size, which I clamped inside the channel. It seems to work OK, but is not quite as smooth as before the accident. (I reversed into it in a L/R with no brakes).
    .W.
