Results 1 to 3 of 3
Thread: No Dashboard lights
    Perth WA
    No Dashboard lights
    Hi All
    I drive a 92 Rangie 3.9 EFI which is currently running on gas only since the electric fuel pump died.
    The large gas tank in boot runs over inspection cover so it's not as simple exercise and as she's my weekend driver only happy to just run her on LPG.
    Went to fill her up tonight pressed the immobilizer button turned ignition and nothing ..... well the lights on the gas guage are off ... Nothing.
    Radio, Hazzard lights. Parking lights work but nothing else.
    Engine will crank over but not start ..... which I expected as no power to LPG
    On closer inspection I realise that non of the normal dash lights turn on when you turn on the ignition.
    Do these have a main fuse .... I started her on Wednesday afternoon and let her run in the carport .... Since then I haven't used her.
    Any ideas ......
    Baggy
    Feb 2013
    Ballarat,Vic,Aus
    Have you checked the fuses ? check the fuses under the front seats as well (slide the front seats forward and look under from the back seat). The fuel pump fuse should be under the drivers seat.
    There is fuses hidden bloody everywhere on them.... so you'll just need to slowly go over it and check everyhing one item at a time. Check the impact switch under the front passenger seat as well.
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Bayswater, Melbourne
    Could also be the dimmer switch which you can just by-pass
