                                                13th November 2017, 11:24 AM
			Nugget Stuff Defender Sway Bay blocks
 Under heavy off road conditions, the rear sway bar can invert causing the bar to rub on the fuel tank, ultimately rubbing a hole in the tank.
 The Spacer Blocks stop that from happening. Can be supplied with extra length M8 as per original fitment, or with M10 or M12 High Tensile bolts, washers and Nyloc nuts to suit the application.
 Specify which bolts when ordering or if not sure, give Nugget a call.
 $88.00 per pair
 Price includes freight with in Australia.
 Can be ordered here :-
 Nugget Stuff Defender Rear Sway Bar 25mm Spacer Blocks – Nugget Stuff
