Thread: lower control arm oil leak
    Mar 2017
    Cobar
    So it appears my lower control arm bush on my d4(2013) has burst and lost the oil, how urgent should I consider this to be as the rubber looks alright and there is no knocking? will this affect my wheel alignment? I do plan on fixing it but just put off by the prices i'm seeing, around $600 for new arms plus I live in outback NSW. Are superpro bushes the way to go?
    Cheers, Kev
    Ellendale Tasmania.
    First off DO NOT get superpro poly bushes it's a very harsh ride, trust me I know because I have them in my D4 at the moment, I must admit though they have lasted longer than OEM, will it effect alignment, I'd say the longer you you leave it, yes, but you will need an alignment after fitting new arms or if you decide to go with having the bushes replaced anyway, which is a slightly cheaper option.
    Get both sides done at the same time soon as you can, there are a couple of options, aftermarket, Genuine and OEM, Les Richmond in VIC have a heavy duty option available, schools out on whether they last longer
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Oct 2003
    Montrose, Vic.
    There is quite a good discussion of LCAs here:Lower control arm bushes
    Earlier this year I put Advance factors LCA's from the UK into mine . I chose the version which have the RRS larger ball joint.
    KIT614 Lemforder OEM Range Rover Sport Front Lower Arms & Bolt Kits LR029304 LR029306 & D4
    So far so good... but I haven't done a lot of Km's so time will tell. It certainly was a cost effective way of doing it and so far I'm not seeing a down side. They have a few options and seem to use quality parts.
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Apr 2016
    New South Wales
    I got the same LCA as the link above, to me there was absolutely no noticeable change to ride quality/harshness
    Quote Originally Posted by Bytemrk View Post
    Mar 2017
    Cobar
    Thanks guys, I reckon I'll order complete new arms for it. I managed to get her up on a hoist today and there is a slight amount of play (two parts of bugger all) so i'll limit the driving as the tyres on this girl ain't cheap. Thanks for your assistance and i'll let you know how it all goes
