Results 1 to 3 of 3
Thread: Stereo Integration D4 09
    Jul 2015
    Victoria
    Hi guys
    Just brought a mobridge m1000-m-da2 to upgrade the sound system ill get installing next week and post pics and as much info as i can.
    As i didnt want to use the high level inputs on an amp or stand alone line level input to rca boxs this unit is perfect it takes the optical signal from the MOST system and changes it to an analog signal for rca outputs for amps.
    I'll be swapping the amp under the seat with an alpine pdx-v9 5 Chan amp, leaving the original harman/kardon speakers but changing the sub to what is still to be decided
    links
    MOST DA2 Analog Pre-Amp | mObridge
    Jul 2015
    Victoria
    ok so its taking longer then expected as im still waiting on one parts, i have changed amps to a jl audio hd900/5 as the alpine wasnt in stock, and now my factory ipod connection is playing up so have to figure that out
    will be back after this weekend with an update hopefully
    Jul 2015
    Victoria
    OK so far so good pulled most of the car apart on Saturday and installed the amp wiring moved the iPod connect from the bracket under the seat and mounted the amp to it, had to remove the seat to gain access to the hold down nuts for the bracket
    MVIMG_20171209_125955.jpgIMG_20171209_125958.jpgIMG_20171209_121834.jpgIMG_20171209_121843.jpg
    watch this guy here its the airbag sensor, where i'm pointing to is the perfect grounding bolt i sanded the nut and the body to get a better grounding but not needed
    amp mounted and power wire connected not to exciting
    below is a bird nest of wires and the computer connected to the mobridge as they're not set up when you receive the module you have to connect it to the dsp program to tell it which car it is and what to decode it to, the bird nest is so i could test everything before i packed up.
    more pics next time i get a chance on finishing the install and once i receive the bits i forgot to order
