Results 1 to 10 of 17
Thread: Solar panels - parallel or series?
    Aug 2010
    Sunbury, VIC
    Looks like st some stage soon I'll be getting 5 x 95 watt solar panels which I was then thinking of running into an MPPT charger such as a Victron 100/50 or similar.
    Being an Electrician I'm thinking I should wire them in series as the controller can handle 100 volts (I'm assuming here the open circuit voltage will be around or just under 100 volts with the panels connected in series here but haven't got the panels yet to check this).
    So, for the solar gurus, is this the correct way to go? Thinking that doing this will reduce voltage drop and allowing charging to continue down to a lower light level as a higher voltage will be maintained on the input for longer.
    Thoughts/theories?
    Feb 2005
    I’m no guru but sound good to me....
    What brand/type of panels??
    Aug 2010
    Sunbury, VIC
    No idea yet - they are a few years old and I probably won't have them for a couple of weeks. I'm not expecting them to perform like new but they should be good for a while yet by the sounds of it.
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Homestar View Post
    im not sure if this will reduce voltage drop.
    but im thinking it will decrase resistance though your wires.
    less amps = less resistance which is useful on hot days.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Aug 2010
    Sunbury, VIC
    Hadn't thought about lower conductor temp that may be possible in a positive temperature coefficient conductor by lowering the amps.
    Crafers West South Australia
    My suggestion is to go series-parallel, keep the panel voltages to under 60V where contact isn't a safety hazard. For 36 cell units OC voltage will be slightly higher than 20V especially in cold weather. Five panels is of course an awkward number to do that with.
    Aug 2015
    Moe
    One of the reputably better regulators around.
    Panels of around 100W tend to have an open circuit voltage (Voc)of between about 18V and about 25V so you may, or may not, be on safe ground. The only way to be dead set certain is to measure Voc.
    Thoughts/theories?
    Series connection will certainly reduce I2R losses over parallel connection given the same wire size.
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Jul 2009
    Hobart
    Hi,
    If I have understood what I have been told, there is also the fact that shade on one panel will lower the output of a series array more than a parallel array.
    Not that you have much choice with five panels.
    Kallangur, Brisbane
    I have always thought that parallel was better when panels could be in partial shade. If wired in series, the one in the shade pulls the others down & the output is less than if they were in parallel.
    + 2016 D4 TDV6
    Aug 2010
    Sunbury, VIC
    Ah, hadn't thought about the shade on one panel affecting the whole system. I could easily go with 4 panels and do a series parallel setup.
