Results 1 to 10 of 14
Thread: Track Rod Loose
    Mar 2015
    Perth, WA
    Track Rod Loose
    Whilst trying to discover the source of clunking in my steering I found that one end of the track rod is really loose.
    It has quite a bit of vertical play, but actually pretty minimal in the axial direction.
    This doesn't seem like it can be right to me, is there a fitting that is pressed into the tube from factory that can come loose? I can't quite get my head around how that bit is joined but can have that much movement.
    I see most replacement track rods are just threaded ends with a lock nut that goes straight onto the tie rod end, seems like a simpler setup to me.
    300TDI Defender 110 if it makes any difference.
    Video below
    Shared album - Matt Davis - Google Photos
    Feb 2005
    Yep looks like something has come adrift.
    I wouldn’t have thought the threaded bit have been pressed in...would have thought it would be machined and maybe it’s cracked through.
    Feb 2017
    Deception Bay, Qld
    That looks like a bodge to me, one style is the tube end should reduce down with the clamp tightening the smaller section around the tie rod threads or like you said a nut on the tie rod thread and whoever did the job didn't have a nut and used the clamp.
    Normanhurst, NSW
    That's not a standard track rod. It looks like someone had tried to reinforce the standard rod by by fitting a heavier tube over the original but has failed to achieve a tight/secure fit betweem the two.
    Roger
    Mar 2015
    Perth, WA
    That's makes sense, and also explains why none of the pictures I could find looked like that.
    I guess in that case it's not actually a major problem since the larger tube is doing nothing other than some protection if it was to get hit.
    Quote Originally Posted by Xtreme View Post
    Mar 2007
    Canada
    The large tube is probably meant to be loose. Some designs do it that way to let the reinforcing bar roll as you drive over things. The original design was called a Sumo bar.
    Torres Straits
    It would be quicker to remove and inspect the rod than take a video?
    Certainly not a standard Rod but as to whether it is a sleeve that is loose (intentionally or otherwise) or looseness in TRE to Rod attachment you won't know till you take the rodnoff and inspect
    If the TRE was threaded into a tube that loose it would fall off likely indicating that to be a sleeved OEM rod
    S
    Feb 2005
    Quote Originally Posted by Red90 View Post
    If it’s supposed to be loose how do adjust the wheel alignment as there is bigger all room where the clamp is, be alright when threads are new.
    I’m wondering if there is movement at the other end. If it a loose sleeve it would contribute to making noises.
    The other sleeve has been machined so a decent crack if it’s a home made job.
    Either way ditch the rod
    Is there any play or jiggle anywhere if someone turns / rocks the steering wheel side to side (engine off-no power steering) while you inspect all the joints underneath?
    If the rod is a problem, you'll see play, otherwise if there is another problem, you should see the play.
    Mar 2007
    Canada
    Track Rod Loose
    Okay not Sumo, but Dan bar. Look it up. Looks like it is one of those. Is there a grease nipple in the middle?
