Results 1 to 10 of 14
Thread: Thunderbolts Way & TD5 lack of power on hills.
    Sep 2009
    So over the years i have read quite a bit on what to check or replace with TD5's.
    My car has an auto conversion and is a 2001 TD5 110. Along the flats is plenty quick enough but this last weekend i found some of the big hills to really be a struggle. No more than usual but i just started dreaming of Toyo V8s!! For anyone who knows Thunderbolt Way i was down to 35kph with my foot to the floor in some parts. Nanocom was reading 120 on the turbo boost and coolant hit 100 before i backed off and got the heater cranking to help cool it down.
    So car has basically a new MAF with no change to power....fixed leaking fuel pressure regulator also for no change and a EGR valve delete and K&N filter likewise.
    No diesel in the oil and i always use a little fuel injector liquid moly conditioner. Engine runs nice an smooth but just hates hills.
    So whats next to check? Im thinking an intercooler clean as i have never done that despite replacing the hoses with silicone.
    Car has 180k on it. Would a dirty intercooler really make that much difference? Is this just normal for a TD5? Its the only one i have driven so nothing to compare to.
    Melrose SA
    I have no idea how a TD5 Defender converted to auto would perform but the Discovery the only auto TD5 ran more boost than the Defender.
    You could up the boost as it sounds you are only running 1.2 bar but if you go too far you will end up with an overboost situation.
    I guess the other question is what transfer case ratios you are running?
    Id check it out and make sure there is nothing wrong (no errors in the ECU) and maybe invest in a remap. But as the car is a 2001 it would of originally had a MSB ecu that couldn't be programmed without physical intervention.
    BUT the question is what did they do when they did the conversion maybe it has an NNN ECU
    Not sure what Jose (TD5inside) could do for you he may be able to send you another ECU if it is an MSB or a remap if it is a NNN the next step would be another intercooler and if you want to spend a bit more try one of his hybrid turbos.
    Don't know anything about the road you mentioned but either its hideous or the car is a lot worse than any TD5 I have driven
    Sep 2010
    The Hills.
    152.79 MB
    A bit out of left field, but have you had the auto, and more particularly, the torque convertor checked? I can't speak for a Defender, but there is no way my Disco would be doing what you describe. Thunderbolt's can be steep, but not that steep, and TD5s go well when on boost.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2009
    Transfer case is a Disco one-No errors on Nanocom and the ECU is original with the 4HP22 being rebuilt 1 year ago and cable operated.
    Fuel pump isnt noisy but is another thing im thinking about.
    Mooney Mooney bridge and the Orimba hill on the Newcastle/Sydney freeway are also terrible with speeds down to 75 or 80 if i dont hit them at about 120.
    Typical for me is to be in the right lane over the bridge at 120+ then cut across 3 lanes to the slow lane part way up the hill.
    Im a bit over doing that and would love to just sit at 110 no matter what. This is next to no load also
    Melrose SA
    What size tyres?
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by timax View Post
    Strewth. I could almost beat you up there in the Scania.. Definitely something wrong IMO. Still, at least you don't have to worry about the wet weather speed cameras.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    NSW far north coast
    Stock engine and 235/85's?
    It's overgeared with the 1.2:1 t/case IMO.
    IIRC I was able to maintain 105km/h coming south up out of Mooney Mooney with an absolutely bog stock D2 fully loaded up from three weeks out west and a roof top tent as a parachute!
    May 2017
    NSW Central Coast
    Yep something's def wrong. The first time I drove a td5 was about 10 years ago. A mate of mine, who is horrible to any car he drives, had a 130 td5 with an old Telstra steel work back full of tools on it, weighing in at 1.4t. We surfed at Myponga (in SA) and I drove it back to Goolwa - pulled 110km/hr up that dirt track which is really steep. Kept going like a train on the rest of the hills but I backed off a bit when I realised the 'tail wagging' wasn't due to the loose dirt road but was actually very worn rear suspension/yoke components Thunderbolts Way & TD5 lack of power on hills.
    Sep 2009
    Quote Originally Posted by rick130 View Post
    Interesting , i thought the Disco transfer case was the thing to have? Oh and yes stock wheels and tyres. I cant remember the rpm at 100kph but might check back with that info.
    Changing down a gear though just makes more noise not a surge of power
    May 2017
    NSW Central Coast
    Does it have a cat converter?
