Results 1 to 6 of 6
Thread: Suspension Bushes
    Mar 2014
    New Zealand
    Suspension Bushes
    Looking to replace the bushes. Am thinking of getting Superpro bushes but am confused with the website. Have spoken to them and they have given me a part number SPF2154K. Anyone used these? Have I got the right part number?
    Irymple, Victoria, Australia
    Stick with the standard bushes, the poly's will only flog out the bush holes in the chassis.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Oct 2014
    Northern NSW.Australia
    Hi,
    I got these. Mine were for the SWB, also listed on seller site., with Tubes.
    Not that intelligent owner, but cant work out why poly bush would flog out, a steel housing.
    Not to offend Mick88, who probably has 40 years experience over me. But why do they flog out ????
    Just keep a check on wear. Plenty of correct grease on service and assembly. Used poly type, on my non Landy 4x4 for a few years, without problems.
    LAND ROVER FULL SET OF SPRING BUSHES & SLEEVES FRONT REAR SERIES 1 2 2A 3 LWB | eBay
    whitehillbilly
    Dirt/dust gets in and then seems to wear the eye in the chassis rather than the poly bush.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    JDNSW's Avatar
    If you have a soft material rubbing against a hard material in a dirty environment, the hard material is worn, due to bits of grit embedding in the soft material.
    I had a good example of this on the County - the nylon fuel line rubbed against a steel brake line below the driver's feet, resulting in a brake fluid leak and a slightly rubbed area on the fuel line.
    The same effect applies for nylon bushes in the chassis or spring eyes unless you can ensure they never move (virtually impossible). Greasing them ensures they do move, and keeping grit from the interface in Australian offroad conditions is impossible.
    If the vehicle does low mileage, mainly on road, you will get away with it, and since the spring eyes are springy and replaceable anyway, this is less of an issue than are the chassis tubes.
    Oct 2014
    Hi Gents.
    Thanks for the replies.
    I only ever grease the inner holes and Tubes and bolts.
    whitehillbilly
