Mine was getting a low boost error randomly after replacing the manifolds and then months later the turbos. On our recent around Australia trip towing my KK it would randomly go into limp mode up the steep hills around Sydney and if I dropped down a couple of gears it would fix itself, thank goodness, since we were in heavy traffic and towing up hill.
We found the problem when we got back to Perth and apparently it was due to a couple of leaking rubber grommets in the manifold, or at least that is what I was told. After fixing that, it has not had an error since.
This is different to the Restricted Performance error you get with a split manifold (which was why I replaced the manifolds) and resets itself without stopping 99% of the time.
				Bob
