Hi Sequel
The Disco1 hilo/CDL lock will work,but only if yours is an auto.There is nowhere to bolt the hilo/cdl acuator on the Disco2 manual box,that was my first try.
I have a Rangie(same as Disco1)HiloCDL acuator,but it was from a manual,it hasnt got the bolt on extensions the auto acuator has,on the Disco1 the CDL,Hi/Lo lever bolts onto a plate fixed to the gear selector on top of the gearbox.The Disco2 is fitted to the floor and operates the Hi/Lo via cable instead of linkage.
Andrew
ops: so the Lancer had to go without covers for a while. They were off the shelf large with attached head rests. I think we paid $180 for the set (fronts only).
