                                                7th December 2017, 08:46 AM
			Bolt/Tie down points rear TD5/110
					Recently got my first 110 and I'm trying to figure out where there are suitable nuts to boot tie downs too?
 The previous owner installed dynamat and aux fuel/water so I'm restricted as to what I can see.
 Does anyone have any pics/details please?
                                                7th December 2017, 11:46 AM
					Pics of my standard tie down points.
 Hole is 10mm ish up from the floor.  Bolts are 8mm from recollection.
 Measurements are 220mm  and 1070mm from the outside of the car as per first pic.
 When i get a round to-it I'll be putting in cargo rails.
 Cheers Glen.
                                                7th December 2017, 02:21 PM
					From memory, you should be able to see them from under the Rear wheel arch.
                                                7th December 2017, 09:06 PM
                                                #4
					douglas track as used in aircraft are good with ancra tiedowns.   Bolt through the floor  into stiffeners below
 http://www.ancra.com/aircraft/pdf/An...Catalog403.pdf
