That does certainly sound like a battery with a weak cell IMHO.  A multimeter should confirm that.  If the voltage drops heavily under load that's often a sign of a dead or weak cell that's only holding a surface charge.  When not overly stressed it will behave like a normal battery and measure like one.  Any decent battery specialist supplier should be able to load test the battery for free.
This is assuming that the battery is getting fully charged (alternator OK?  Driven long enough to replenish, etc?) and there are no unusual drains on the system.
				DiscoClax
'94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
'08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
