Thread: Rear Wheel hanger
    Oct 2013
    Ballarat
    Rear Wheel hanger
    If you have a rear wheel hanger fitted , check the bearings .I have had a top bearing collapse recently PITA it is get the old cups out .So every couple of years check them and repack them will make the job so much easier .
    I drilled and tapped in a grease point, I just pump a slug of grease in there regularly Rear Wheel hanger
    Oct 2013
    Ballarat
    Yup next project to add to the list I have the other side to do soon
    Ocean Reef WA
    Is a "rear wheel hanger" an RWC by another name? If so, because it moves so infrequently I wouldn't think it needs more than an initial greasing. I've had 2 (or is it 3 ) Rijidig carriers and have never had a problem with bearings and even on lesser RWCs from overseas that has never given a problem.
    Cheers.
    AlanH.
    Oct 2013
    Ballarat
    ATH thats what i would have thought , once a week if it was lucky , but no the top bearing collapsed , now running a Timken set in there
    Oct 2014
    Doesn’t move many times in rotation but I guess could get pounded on rough roads specially if there’s any tolerance to vertical movement at the latch.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Aug 2015
    Quote Originally Posted by LRD414 View Post
    Mines squeaky, sounds dry as a bone, it's on the to-do list.
