Originally Posted by
Geedublya
If you are not driving short trips and let the DPF regen complete its cycle you will be OK. Most of these problems come from short trips. If possible run an additive which will assist combustion helping prevent the DPF from doing a regen as often.
That would depend on how the regen activation is triggered. Some may trigger on fuel burn, some may be on DPF differential pressure etc.... If its monitored from an actual differntial pressure sensor setup then yes you could in reduce the DPF regen cycles. If its calculated from a fuel burn rate from the manufacturer then it most likely wont make much difference as they will do a regen for whatever its been calculated/programed to do
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
