Results 1 to 10 of 11
Thread: Rover 2.6L bearings
    Oct 2010
    Garvoc, South West Victoria
    Rover 2.6L bearings
    I plan to replace the main & big end bearings on the 2.6 six cylinder engine in the near future and was wondering how easy they are to obtain?
    I have heard the bearings were interchangable with a Series I four cylinder Rover engine but I can't remember which. Would this engine have been the early 1.6L or the later 2L?
    Are the 2.6L bearings interchangeable with the Rover 3.0L?
    REMLR Registrant No. 436
    LROCV Member No. 1703
    1976 RRC Suffix D
    1979 Series III GS FFR
    1980 Series III GS FFR with a Perentie RFSV tub
    1991 Discovery 1 3.5 V8 3 door
    1993 Discovery 1 200Tdi 3 door
    1993 Defender 110 200Tdi ute
    Aug 2010
    Sunbury, VIC
    Bearings are available but can be a bit hard to track down. I found a set of mains locally but big ends had to come from England.
    Oct 2010
    Thanks Homestar,
    Where did you get the big ends from? Cox & Turner seem to be the ones to go for Series I IoE engines Home | Cox & Turner Engineering
    1976 RRC Suffix D
    Aug 2010
    Sunbury, VIC
    Just by trolling through eBay UK. Found a set - he wouldn’t post OS, but I got them delivered to rellies in England and Mum grabbed them for me on a trip home.
    Don’t think I’ve sourced much through any of the major players, just kept my eye out.
    Aug 2010
    Sunbury, VIC
    If you want to regrind the crank, here’s a set of 30 unders. Land Rover 6 Cylinder(2.6) & Rover P4 P5 Big End Bearings -0.030 | eBay
    Aug 2010
    Sunbury, VIC
    Set of mains assume are standard but he’s dreaming with the price as far as I’m concerned Brand new genuine Land Rover 2.6l 6 cylinder engine bearing, RTC1720 | eBay
    Oct 2010
    Thanks Homestar for your help - much appreciated!
    I'll have to take the sump off to see how worn the current shells are.
    Intriguingly the engine was replaced 1 year after it was complianced and the REMLR records have the original engine number listed.
    Also the fuel tank has a postage label addressed to the Puckapunyal Army camp so its had an interesting past!
    1976 RRC Suffix D
    really, it's not worth looking for bearings until you know what size bearings you need,
    but I would try Repco first.
    I recently did my 2a 2 !/4 and Repco supplied them the next day.
    Safe Travels
    harry
    Aug 2010
    Sunbury, VIC
    The 2.6 bearings aren’t available any more (Tried local, specialist and international sellers) so finding NOS is almost the only way to go. I think standard sizes are pretty common but not many people needing standard sizes any more.
    Narre Warren South
    Listed here but you'd need to contact to find availability. Rover | Landrover 95 | 2.6 Litre (2A) Parts List - Precision International
    Still available -.030" big end bearings here Land Rover 6 Cylinder(2.6) & Rover P4 P5 Big End Bearings -0.030 | eBay
    Four Wheel Drives (now in Hallam) used to carry them, they got a lot of parts from the early army auctions. Problem is with several changes of ownership recently they wouldn't know what they've got now. If you phone them make it a Mon, Wed or Fri and ask for Murray.
    If you approach an engine reconditioner they can often use their supplier network to track them down.
    Bearings are the same as the Rover 3litre.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
