Thread: Wobbly Removable Tow Hitch
    Aug 2017
    NSW
    Having just got myself a bike carrier for the rear of my D3, I've noticed that the removable tow hitch tends to wobble a bit when subjected to twisting forces. The hitch is rock solid when connected, and doesn't appear to be a connection issue, but the extra leverage which the bike rack shows up a a bit of swaying.
    In the video below, you can see the detachable tow hitch moving side-to-side inside the receiver.
    Has anyone experienced this before? Is it normal? Does anyone have any suggestions about good ways to make it more rigid (other than swapping out for a mitch hitch)?
    Thanks,
    St Helena,Melbourne
    1.13 MB
    Does seem pretty loose, is it engaged properly ? Not that i have used mine much but i never noticed it wobbling like that.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2017
    NSW
    Definitely appears to be fully engaged, and the only movement is side to side (no movement forwards/backwards or up/down)
    Jan 2013
    Quinn's Rocks W.A
    My bike rack has a strap that attaches to the top of the back door, ( has a little L clip to slip it into the gap between door and the roof ) pull it tight and stops most of the movement.
    not all, but most of it.
    jack
    Oct 2012
    Mine wobbles just as much with bike carrier but is less noticeable when loaded and makes no difference overall
