Results 1 to 10 of 14
Thread: LPG on a Diesel
    N.E. 'burbs Melbourne
    LPG on a Diesel
    I know this subject was discussed earlier but........
    Has anyone fitted LPG to a TDI300 Disco auto?
    I'd love to here any pro's or con's.
    Saw it at the Vic 4WD show and had a good chin wag with the guys there but I just want some "real world" experiences with it before I shell out my $4K.
    Robbie A.
    May 2002
    Sydney, Australia
    like most others, we are all standing back to see what are the real results!!!
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Adelaide Hills - SA
    Didn't know you could do this to a Diesel!
    Is it the same LPG that you put in a petrol engine?
    Toowoomba QLD.
    Try here
    www.dieselgas.com.au/home.htm
    Trev.
    Adelaide Hills - SA
    Thanks DiscoNut - that is a good link.
    Estimated "payback" time of 100,000Km seems very high, although you get a heap more power along the way.
    I wonder if this an alternative to chipping the ECU? Pity it costs $4000.
    Toowoomba QLD.
    The benefits lie in "dual fuel" in as much that you increase your fuel range, (extra tank fitted), and reduce your imported fuel requirement. ie use less diesel as it is offset with lpg.
    LPG is a domestic fuel and should remain at a more stable price and because it is domestic, security of supply is almost gauranteed. (nothing is ever 100% certain).
    The power increase is a bonus.
    Cheaper to go with a chip ($1000), and a big bore pipe, ($1200.00). Rough figures.
    Your choice!
    Trev.
    Oct 2003
    Gold Coast, Qld.
    One of our guys here Dranged is running it... says it gives a heap of extra torque and horsepower.
    RAAF Tactical 200184 & 200168
    Yass NSW
    I do 45,000 k a year so it wouldn't take long to recoup it but the $4000 outlay is off putting and also the longterm reliability as mine is already chiped and modified (I still havn't work all the things they have done to it)???
    Brisbane, north of the river
    Hiya'll.
    Dunno if you realise this but you're all talking about chipping whereas wozzlegummich originally said he had a 300tdi, could be tricky to chip :wink:
    Toowoomba QLD.
    Originally posted by Grizzly_Adams
    Hiya'll.
    You are correct. it went off track after this:
    "I wonder if this an alternative to chipping the ECU? Pity it costs $4000."
    Trev.
