Results 1 to 10 of 29
Thread: 2000km in the High Country/ Defender TDCI 130
    May 2011
    Barnawartha
    Thought I would make a few comments on how the 2010 130 went over the last few weeks up in the Vic high country. We have had the truck for 3 years now, so it is just about sorted…….
    ATB Centre diff has an unforeseen advantage: with no ABS the brakes are dreadful, steep descents on rough terrain has always seen the 130 skipping its way down every time a wheel unloaded. Still does so, but to a noticeably lesser degree. Works well on the loose dirt roads as well of course, and considering it was primarily fitted for reliability/strength, it has been more than worthwhile.
    I always considered our ’76 Rangie as the best climbing vehicle we ever owned. Chug away at low revs, it would climb up just about anything. Put your foot down and the sky was the limit. Amazes me that something the size and weight of a loaded 130 can behave in the same way. We have the 160BHP Bas tune, but also a nervy navigator, so the climbing is done as moderately as possible.
    Bilstein shocks now fitted and being the correct length we now no longer have to stop, after some spring flexing, to pry the rear coils back into place, unlike the Terrafirma days. Original springs, still copingwith everything we throw at them.
    We run two TJM ProLockers, I can’t praise them high enough.My excuse for fitting the rear was to help with the downhill braking…. And then the front diff was committing suicide anyway….. Now the navigator thinks theyare worth every penny. WooHoo!
    The famous youbeaut Anti stall, 1st low. Climbing hard out of the Cobberas Track, we tackled one too many rock steps in 2ndand stalled. All the hype I have read, I assumed that a restart in first would be a piece of cake. Had to wind it up to 2500rpm before we got moving at all (reallymiss that hand throttle). I have no doubt that if I was in first (as I shouldhave been by then) that the anti-stall would have climbed out fine. But as a hill start, no way.
    First low just not low enough! Riding those damn brakes(think I mentioned them already?) all the way down a reasonable descent to keep revs below 3000rpm. I did ask Pete Bell if there was a way of increasing enginebraking, but no. I will have to investigate transfer ratios I think. The engine braking does appear to have improved a little with all the headwork that has just been done, but that is another story.
    I fitted Hankook DynaPro MT 235/85 last year, they are performing well on and off road with minimal wear. A compromise of course, a little noisy for a road tyre, not aggressive enough for a true mud tyre. I also found them a little touchy to get the pressure right. 30psi, lovely in the bush, sloppy on the bitumen, 35 psi harsh in the bush, great on the road. Sweetspot in the middle seems to be fine though, so will probably go with them again when the time comes.
    We use an Oztent RV1, mounted across the outside rear of the truck, the major rain events while we were away has changed one thing: we now wrap the tent in a waterproof tarp before it gets packed into the carry bag, the fly handled 40mm of rain overnight fine, and we even set the side panels up for the first time (in three years), quite comfy in a minimalist way. The 140mm rain we did find a more solid and larger overnight stay for…..
    Going bush in the Vic high country in December means youpretty much have the place to yourself, apart from a few parties that gave deerhunters a bad name (Dogs in national parks, Driving around locked gates,spotlighting and shooting within 100m from where we were staying…interesting little chat at 1.00am for that one).
    I would love to post some pics of the Landy in action, but all I can find are Brumbies, water dragons, Brumbies, birds, Brumbies, orchids, Brumbies and gold mining relics. I don’t get to play with the camera much…
    Rich
    May 2017
    NSW Central Coast
    Nice trip by the sounds Rich.
    Interesting to hear your comments on the tdci 130; it will be interesting to compare to my td5 130. I debated long and hard over what to replace my tdci 110 with!
    You didn't happen to see a D4 rolling (the wrong way) through the steep stuff while you were there did you? I saw a photo on Friday of an expensive looking mishap in the VHC 2000km in the High Country/ Defender TDCI 130
    Nov 2017
    No ABS?
    No ABS on a 2010? Excuse my ignorance but I would have thought it standard on the Puma? Or am I misreading?
    May 2011
    Barnawartha
    Colmoore,
    Saw lots of the steep stuff, but no D4, hope they got out alright.
    Good luck with the TD5, and welcome to the world of 4 point turns.
    Stinkler
    I think the ABS was an option on the TDCI 130 in an effort to keep costs down. Whatever the reason, I don't have it
    Rich
    Nov 2017
    Ok, good to know.
    Sounds like a great rig and excellent adventures, good reading and look forward to more.
    Jun 2013
    Warner Area - SEQ
    Quote Originally Posted by FV1601 View Post
    Interesting to hear that u don't think the 1st gear LR is lower enough..... Love to know what u think of the TDi/Td5 1st gear LR then.... Scary stuff
    May 2011
    Barnawartha
    Rob, first gear going up is fine, it's down that is the problem. You can only squeeze so much engine braking out of small motors I guess, but we are carrying loads that the 130 is supposed to be designed for....
    It's been a while since I had the TD300, I'm not even allowed to talk about that one!
    Perhaps a few years with a TD42 Patrol gave me an expectation that the middle pedal actually worked, even if you did not need it with all that engine braking up front. Really a shame that it was nowhere near as fun as the Defender off road.
    Rich.
    Sep 2010
    The Hills.
    152.79 MB
    Interesting. My 300 D1, admittedly lighter, and rarely loaded up, has a set of MaxiDrive reduction ratios in the TC ( ashamed to say I don't know the ratios, but it will climb anything if it has traction ). In low first I need to use the loud pedal to maintain movement down steep hills, or the thing will stall and stop. Diesels have mighty compression as a rule.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2011
    Barnawartha
    Johntins
    Sounds like I need to investigate Maxidrive Transfer ratios!
    Rich.
    Apr 2011
    Windsor NSW
    no ABS
    Puma 130's did not get ABS or traction control until after MY13 models. Have to agree engine braking could be better in standard trim.
    Alan
