Results 1 to 10 of 19
Thread: Discover 4 Suspension
    Dec 2017
    Sanctuary Lakes
    Hi there,
    The Landrover specialist in South Africa where I lived until earlier this year installed a program into my Disco 3 which allowed me to change the height of the car when going offroad to give me an extra 50mm lift. Since I returned back home to Melbourne I bought a disco 4 and would like to do the same thing.
    While doing some research on the internet I stumbled upon Land Rover Passion who do an app and module to do this and I was wondering if any anybody had any experience with it or could advise on alternatives preferably locally made.
    Thanks in advance.
    Dec 2014
    I use this one and it is very popular
    IIDTool - Gap Diagnostic
    Oct 2016
    Perth, AU
    Do a search for LLAMS if you want a locally built, hardware based option
    Otherwise the IID tool can give similar functionality, and might be fine for occasional use
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Go for LLAMs - designed by a member on here - support local when you can.
    Works with the twist of a knob - not need to plug anything in etc.
    Dec 2017
    Sanctuary Lakes
    Thanks for the quick response. I'll look into these options.
    NSW SW Slopes
    Quote Originally Posted by Miffy View Post
    Was the LR specialist Torqtune? They sell/install my Llams kits.
    Oct 2013
    Old Toongabbie, Sydney NSW
    The LLAMS is a great piece of kit and I considered buying it very seriously as I already had a Nanocom for diagnostics etc. However, I ended up buying a GAP Diagnostic IID Tool Bluetooth version as it provided me with the functionality of the LLAMS plus the convenience of use by an app on my phone via Bluetooth. My main use is to lower the car to allow better access for my disabled wife. With the IID Tool I can lower it to bump stops and it is very low. I could not do this efficiently ( that is quickly) with the Nanocom which was important to me as I am usually needing to drop swmbo off where people are waiting behind me. You can set up three heights to use plus default. I sold the Nanocom to a member here and recouped some of it's cost. IMHO, if you don't have a diagnostic tool already the IID Tool is the way to go as it gives you much greater functionality.
    Martin
    Mar 2016
    If I was raising and lowering regularly I’d probably have invested in the LLAMS. As I only play when travelling to stop the wretched “slow down or ill lower and **** you off”, the inconvenience of loading up the IiD app etc is ok. Horses for courses
    2007 Audi RS4 (B7)
    Ocean Reef WA
    I was out playing in the sand yesterday (and getting bogged) and lifted the "D" to get the guts off the floor. Then a message came up on the dash saying that for further lift I should press the height altering button and put foot on brake and it worked. There was another message which said to lower the vehicle asap after use. I presume this was to avoid extra strain on CVs etc?
    AlanH.
    Mar 2016
    Quote Originally Posted by ATH View Post
    AlanH.
    In extended / super extended height the vehicle is less stable and yes, probably risks other damage. It’s meant to be temporary only.
    2007 Audi RS4 (B7)
