Results 1 to 3 of 3
Thread: Replacement Battery - reset BMS
    Jan 2009
    Perth, WA
    Hi
    I've just had my cranking battery replaced (had a wet battery in there, and have just put a Varta AGM back, as per original).
    The workshop manual says that the BMS should be reset after replacing the battery.
    I know where to do this using my IIDtool - my question is - which battery type should I choose out of the menu options?
    I'm sure I've seen some info on a post here somewhere, but for the life of me, I can't find it...
    Thanks.
    Rob
    D4 3.0L SE, MY10, Arctic White
    ARB Colour-coded bullbar, Safari Snorkel, Traxide DBS, LRBT1 BT audio module, trying out some 19" Maxxis Bravo 980A/T's (ex Cooper Zeon LTZ's)
    ex D1 2.5L 300Tdi, MY97 - loved it, gone to a better place.
    If it's a Varta G14 you have fitted, they are 95 Ah and 850 cold cranking amps so choose the closest to that from the list in the CCF.
    BTW, the 'list' your talking about is in the CCF file. If it's a "battery reset" your really wanting then that is found in the 'service / test' > 'BCM body control' > 'battery replacement' menu. There is no list of batteries to choose from there, just a reset function.
    The point is, if you have just changed batteries you may need to make this change in 2 locations in the GAP tool menus.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Jan 2009
    Perth, WA
    New battery
    Quote Originally Posted by Ferret View Post
    Thanks for the clarification. I'm pretty sure this hasn't been done (in either location) when the battery was last changed!
    Some fun for tonight!
    Rob
