Finding someone with the 5 on 165 finger plate will be your challenge.
A couple months back I got some km2's for the defender 90, 285x75r16s on king 16x8 on 0 offset. Trying to get them balanced is proving difficult, does anyone know a place in or around ipswich that can do a decent balance with a finger plate?
 Wizard
						Wizard
						The balancing plate for lugs are usually adjustable for any bolt pattern.
What you can do is bring in a spare hub and they can put that on the cone.
Never mind the bollocks
Tire/Tyre Balancing Beads- 245/75R16, 245/70R16, 235/75R15, 265/70R17, 225/75R15 | eBay
I’ve had good success on hard to balance hoops
With 100gm of this then spin it up on the balancer if more is needed
S
I've never seen these before...... what do u do with them?
QUOTE=roverrescue;2754265]Never mind the bollocks
S[/QUOTE]
They go inside the tyre
These are the ones I used Counteract Balancing Beads | The only tire balancing product proven to improve fuel economy.
I can't recall how much now, but we had to add extra to get the tyres balanced properly
Tried the beads on the D4.
Biggest disaster ever!
Removed and conventional balance and all was good...
Seems mileage may vary!
 Wizard
						Wizard
						Air soft pellets are cheap and work as well.
