Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Tyre size
    Oct 2014
    Tyre size
    Hey All my D3 was fitted with some big rubber by previous owner 275 70 18s that work out to a 33.
    What are others running , thinking a 265 60 18 Lt Alk Terrain might be a good size
    1976 LR 90 Hybrid GONE
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1980'RRC Build in progress GOING
    Disco wrecking 93 & 94
    1993 RRC LSE
    Aug 2008
    Perth, WA
    37.36 MB
    I currently have 265/60/18 D697 LT's and they are a good compromise size. Better onroad than 17's and better offroad than 19's, if you know what I mean.
    LRD414's Avatar
    Oct 2014
    The two most popular sizes are 265/60/R18 and 265/65/R18 but there is also quite a few running 285/60/R18. The first one has the advantage of still fitting a fully inflated spare and no rubbing in any position. The other two have the advantage of more sidewall and slightly more clearance but some rubbing and difficulty with fitting the spare. I have also seen the 285 sized spare drag on the ground significantly more in steep pinches. All depends on what trade-offs you’re happiest with.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Feb 2009
    And setting the new tyre size is possible with the gaptool right?
    Oct 2014
    Like the idea of this size
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by Lockee View Post
    255/70/R18 = 814mm diameter.
    That's pretty big but slightly narrower than other 18" options.
    Hard to say what the rubbing issues would be without test fit.
    Would also need to confirm if there's any room in the arches if on the bump stops.
    Is the KO2 LT rated in that size?
    D3 2005 V8 Petrol
    Oct 2014
    Running 275 70 18s at present but rubbing
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Aug 2016
    Not sure that last size is available in Australia. If it is it is probably a grey import like my BFGs are and BFG Australia will not warranty
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    Oct 2014
    Bit hard when I do work for BFG....
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Oct 2014
    Quote Originally Posted by dirvine View Post
    What do you run?
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
