Sounds as if you are not getting it engaged properly. This could be eitther, as you suggest, 'operator error', or it coulod be either something such as ther boot, interfering with the lever movement, or a problem with the linkage between the selector fork and the lever, usually a clamp bolt loose.
Rarely, it could be an internal problem.
