Thread: Air Con Vents
    Scarborough, QLD
    Air Con Vents
    Anyone with a RRC with these style vents - Vent Facia - Paddock Spares - able to provide the outer dimensions? I'm hoping they might fit as a replacement to the dodgy Defender vents.
    I'll check the sizing but think they mount differently
    84 Alfetta GTV
    I think a got a few spare RRC vents if you want them. I sold the Rangie so don’t need them anymore. I’m in Melb
    Nick
    Feb 2013
    Ballarat,Vic,Aus
    The rangey ones aren't great. You will find they close themselves all the time ......................
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    G`day ,
    somewhere in the paddock of 56mm in height , they have around 3mm of curve on that plain to the fitting surface .
    The length has a taper of around 2.5mm . The variance would be around 138.5mm and 136mm
    Depth of the body around 23mm at worst with the vent body square around 32.5mm overall and with the vanes open at right angle to body add around 8mm
