Thread: Charging flat battery
    Jan 2014
    Newcastle
    Hi All, twice over the last. fortnight we have now had a flat battery whilst camping in our 2008 D3. My guess is opening and closing doors too much!
    Either way I understand that I should properly charge the battery. I have a Project IC1500 for my Camper trailer and it looks like it would do the job.
    https://www.projecta.com.au/battery-charger-products/12v-automatic-15a-7-stage-battery-charger
    I am concerned though about frying electrics. There is so much talk out on the internet.
    My understanding is - pick the right battery type, connect the cables in the correct order then turn the charger on.
    I am also not sure which charge rate I should use, the table on page 10 refers to AH, I assume that would be Amp Hours?
    Is that right.
    Am I missing something significant?
    Feb 2017
    Your battery shouldnt being going goat from opening and closing doors at camp. Especially if you adjust internal lights not to turn on. I have had my radio blaring for 3 hrs(aux socket relay jumped) and still not get a flat battery. It might be a old battery? Or a drain somewhere else?
    06 Disco 3
    Jan 2014
    Newcastle
    Thanks UberDisco, The battery is 2.5 years old, and we hadn't set the lights not to turn on. I really should have thought of that! But yes, I do need to investigate the cause.
    I will take the car to a battery shop to get them to check the battery this afternoon. Assuming it still has good I plan to connect it to the charger later tonight. Just want to make sure I follow the steps correctly.
    There is nothing special about charging a battery in a D3/D4 except where the -ive charging goes - on the body earth post rather than the -ive side of the battery. Just take the same precautions as charging any car.
    When my old battery was dying I had to charge it a few times using my old supercrap smart charger - positive clip to the +lead on the battery and the negative clip to the earth post on the body just in front of the battery - and just left it until the charger said charged - no issues.
    Jan 2014
    Newcastle
    Thanks GarryCol, I have read today about the location to put the -Ve lead, not on the battery.
    When we jump started the car I did actually connect the -Ve directly to the battery. What risks were I running? Gulp ...
    Feb 2010
    Camping Access
    Turning internal lights off whilst camping is one method of minimising battery use. However, probably the greater current draw over time is frequent door opening. Every time a door is opened the cars system initialises expecting to be started. Leaving one door ajar while camping allows the vehicle to shut down electronically. This may be significant if you have several passengers accessing the vehicle just to get to their toothpaste, drink bottle or iPad.
    A healthy battery also helps.
    Quote Originally Posted by corbijn View Post
    Nothing - car systems if on may misread voltages etc while charging - don't over think things.
    Dec 2016
    Buderim Qld
    Quote Originally Posted by AGRO View Post
    What makes and models are you talking about here? I never knew my car expected to be started when I opened a door.
    DiscoMick Guest
    Is that right.
    If your Projecta has an auto function on it then just set it to auto and leave it to do the job. A multi-stage charger will test the battery as it charges. When it is almost charged it will step down the charge rate. Eventually it will decide the battery is charged, stop charging and periodically wake up and test the battery to see if it needs a boost. That's how my Projecta works
    Dec 2011
    Forrestfield WA
    Quote Originally Posted by Kidbeen View Post
    The cars in this section of the forum, D3's and D4's!
    The car wakes up and readies everything for starting if necessary. It doesn't actually have to be started but does take power to do this checking and waking up. When the parking brake symbol goes off, assuming the parking brake is on, the car has gone back to sleep.
    Bob
