Results 1 to 10 of 31
Thread: THOR high comp 4.6 camshaft
    Jul 2016
    adelaide
    hi guys,
    are there any comments regarding choice of cam for a 9.37:1 4.6 thor engine with vapour injection LPG? mine could do with replacement and it may as well be as worthwhile as it can be.
    i'm more interested in low/mid torque and economy. without a change to injection (which i'm not interested in undertaking), is anything but the stock cam even worthwhile?
    lots of info about early cars and gems but not so much thor
    thanks!
    May 2003
    On The Road
    Feb 2013
    Gosford, NSW, Australia
    I have a Crow Cam - they make two versions for the 4.0/4.6 - Crow Cams - the most advanced cam development and CNC grinding facilities in Australia .
    Feb 2013
    Hi
    Did you fit the HT969-16 lifters as well?
    I am thinking of replacing my cam when I do my lifters and pushrods
    Stev
    Jul 2016
    adelaide
    thanks for the responses
    Pedro, is this what you've used? is other machining required (guide height etc) in addition to new valve springs?
    Steve, are they suitable for use in a serpentine belt engine?
    Garry, which one have you got? the car will mostly be normal driving, occasionally some sand or towing work, but mostly road stuff.
    has anyone any experience with the Dynotec 216 which is what i think TRS supply?
    such a confusing and difficult to quantify topic given that there are so many variables - stock cam gears, degreed crank gear. compression ratios, etc.
    Quote Originally Posted by TheTree View Post
    Hi
    Stev
    No - my engine is standard so stayed with standard pushrods and (new) lifters.
    Quote Originally Posted by mpwdhc View Post
    I went for the 371771 but my engine is not in a D2 or P38. It is going in my 101 which is low geared - so at low speed etc the gearing provides plenty of power but I cruise on the highway at around 3000 rpm where torque on a standard RV8 starts to drop off so I wanted more torque higher up the rev range.
    That is probably not needed in a P38 but I am not sure - the chart I put up has the rev range for each cam where you can expect best performance so you need to select what suits best - at my 100kph the same revs probably are giving you 160kph so different requirements.
    May 2003
    On The Road
    Yes,, on Turners reccomendation. Very happy so far, but the Tornado ECM makes a bigger difference....
    Jan 2016
    Netherlands
    I should think that as far as cams are concerned the gems and thor are the same? In any case in my gems I have a piper285 and a tornado chip. afaik it should fit the thor as well. More mid torque and more high end power. The only real downside is a slightly rougher idle, but since the P38 is an auto box, you won't notice it unless the engine runs in park or neutral (unloaded)
    I have a chart at home with everything that was changed on my engine but afaik you can run this without modifying anything else though port and polish of the heads is recommended.
    -P
