Mulgo Expedition Centre used to do a two way filler on an exchange arrangement, for the new one and return the original.
No longer on the website but it might be worth dropping Daniel a line.
 2nd Fuel Tank Filler for a Sill Tank - Where to source one?
		Gents....
I'm looking to install a sill tank & I was wanting to just tap into the original fuel filler (ie have a "Y" joint made up) but I might have to change my mind due to the cost of having the original fuel filler modified into a "Y" type filler. The bloke I saw quoted me somewhere between 2>4hrs @ $100/hr which is just getting too expensive for what it is....
So, I'm now looking at installing a second filler just below the passenger's door in that triangle section where I've seen a few on here put theirs, but I can't seem to find a suitable 50mm filler to install. I was wondering what people have used and where they have sourced their filler from?
Also, I'm wanting a 2nd filler that is "lockable" too.
Any help would be greatly appreciated
Rob
 Master
						Master
						I have a spare one I pulled from a Brown Davis fuel
Tank if you want
 Wizard
						Wizard
						This is a 30 minute job. The guy needs a new profession if it takes him four hours.
 ChatterBox
						ChatterBox
						You get some funny looks at the petrol station but I just cut a hole in the top of the tank and another through the drivers floor. Open door, remove cap, fill tank. The floor mat covers the hole
I used one of these in the top of the tank, with the barb cut off
Deck-Filler-amp-Key-Boat-38mm-316-Marine-Grade-Stainless-Steel-Fuel-Flush-Mount | eBay
Works for me
 Master
						Subscriber
						Master
						SubscriberMy 2 nd tank filler pipe is from an old Holden fuel tank, some of them are quite long,so you can trim to size, you can buy a lockable cap if you need to.
re the Y joint for the second tank filling, some silver solder will do a fine job, no need to weld it, 30 minutes work if you have oxy gear or a mate who's a plumber.
cheers simmo.
simmo
95 300Tdi Defender wagon
