Results 1 to 8 of 8
Thread: Check your drop arm ball joint
    South Yundreup,WA.
    If you have not done recently check the drop arm ball joint. This one looked the best out of the 4 ball joints but ended up being the worst. The other 3 all had perished boots but still had grease in them. The drop arm ball joint was just dust no grease and these are supposed to be greased for life. Why I have fitted ones with grease nipples and drilled and tapped one into the drop arm ball joint.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Had to do mine...
    Not a nice job when its this bad.
    Cheers Rod
    Feb 2010
    Yikes! That's some good dust.
    (sorry that's a useless contribution I know haha)
    Hay Point
    Looks like lots of water has been trapped in there Rod.
    Cheers......Brian
    1985 110 V8 County
    Apr 2014
    Thats the way i got it. Glad i checked it...lol
    I've had to replace mine once in 625,000km, so they are not a frequent failure item. But any damage to boot will let in water, and the damage may not be all that apparent.
    South Yundreup,WA.
    John,
    The one in mine had no damage to the boot at all and as said actually looked the best of the 4. Inly 220,000kms
    Craig
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Nov 2012
    Acacia Ridge, QLD
    Steering control ball joints & boots.
    I recently replaced all 4 boots on my steering, they don't take long to do, about 20 minutes each, as soon as one of them gets cracked I just replace them all, they look like natural rubber, so they don't last forever.
    I scoop out the existing grease, and repack them generously with molybdunum disulphide grease. The little rubber boot is about $8 from memory.
    If you look at them each year you'll notice them deteriorating. Its better to keep on top of them than have to replace the ball joint. I also spray the steering rods adjustment threads with Lanotech or fleece grease while Im there, to they don't seize together with corrosion.
    cheers simmo.
    simmo
    95 300Tdi Defender wagon
