Results 1 to 8 of 8
Thread: Anderson plug voltmeter
    Scarborough, QLD
    If I put one of these ANDERSON TYPE PLUG WITH VOLT METER 50A - Allvolts Power Solutions Pty Ltd on the lead from my Defender auxiliary battery that goes connects to the slide on camper (which also has a deep cycle battery), which voltage would it read, the Defender, the camper, or something else?
    Oct 2013
    Richmond, NSW
    Hi Ranga, can’t answer your question but a pretty useful little device. Thanks for sharing:-)
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Jan 2017
    Geraldton WA
    I bought a couple of these that have many more readouts as well as voltage
    150A Digital Volt Amp Watt Meter Solar 12V Ammeter Voltmeter Caravan 4x4 Camping | eBay
    4.6m Quintrex boat
    Queensland
    Hi Ranga, that’s not a bad idea but it is also a bit useless in that you need to be get to it to be able to get a reading.
    This could be very difficult if your Anderson plug is in a hard to reach location.
    As to your question, if both batteries are connected but the motor is off, it will display a voltage reading that is the common voltage of both batteries.
    If the motor is running, it will display a PROPORTIONAL voltage reading based on how high the voltage is coming from your alternator at one end of your cable run, minus the amount of voltage drop caused by the battery’s SoC at the other end of your cable run.
    If your auxiliary battery is in a low state, depending on how far from each end the unit is located, could make for a VERY erroneous reading, if it the voltage at the battery you are looking for.
    Hi Trout, unfortunately those devices are not much use for measuring CONSTANT current loads over about 15 to 20 amps, because the cable on them is way to thin and just heats up.
    Feb 2005
    Quote Originally Posted by trout1105 View Post
    I brought one of these but got frustrated with how quickly they cycle through the reading.
    Jan 2017
    Geraldton WA
    The wiring that came with mine seem to be fairly substantial and don't get hot when hooked up to my solar panels or even from my alternator charging 3 batteries at a time
    4.6m Quintrex boat
    DiscoMick Guest
    I'm no expert like Drivesafe, but I guess it's going to tell you whatever the voltage is running through the cable. As Drivesafe said, that could be affected by several factors, including the state of the batteries and if the alternator is charging the system. If you connected it directly to your auxiliary battery and very close to it, then it might mainly read that battery, I guess. If you have solar connected that could also affect it.
    Jan 2017
    Geraldton WA
    Yes that is annoying.
    I do like it that you get an cumulative AH reading that tells you how much power has been added to your battery over the day from your solar panel though
    4.6m Quintrex boat
