Results 1 to 10 of 13
Thread: Car cut out
    kero Guest
    Car cut out
    Ok brains trust. Stop talked to my son ,fired up onto freeway doing about 90 motor cuts out, was low on fuel since transfer 1/4 tank over NRMA man from Yass stumped. Motor kicking over but not firing. Thanks Kero
    Jan 2017
    Geraldton WA
    You will have to let us know what type of car and engine type for us to be of any help
    4.6m Quintrex boat
    kero Guest
    Car cut out
    Diesel 2013
    kero Guest
    Car cut out
    Codes are cleared , still no start. Sounds like not getting fuel
    Dec 2009
    Ranelagh, Tasmania
    Car cut out
    Check for fuel at the Schrader valve on the low pressure fuel line. It has a black or red cap from memory. Turn the ignition on with the valve depressed or removed and fuel will come out. If there is air or no pressure you either have an empty tank (possible bad gauge sender) or a faulty in tank pump.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Nov 2015
    Black Rock
    Low Pressure Fuel System Bleeding
    The attached may help. It talks of a special tool, but I'm sure a workshop will make do with something.
    Attached Files Attached Files
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Dec 2009
    Ranelagh, Tasmania
    If you ran the main tank dry you need more than 20l to prime it again. You can prime the line by pressing the valve in or removing it and turning the ignition on and off a few times until no air is pumped out. Fuel will spray and it will be hot, ask me how I know.
    2023 Ford Ranga
    Mar 2015
    Engadine
    Quote Originally Posted by DieselLSE View Post
    How to do this without a special tube. You actually don't need a schrader fitting. 1/4 fuel line fits over the valve snugly.
    DISCO3.CO.UK - View topic - Rectifying a misfuel - DIY at the petrol station + photos
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    kero Guest
    Quote Originally Posted by Oztourer View Post
    Well car is fixed , car was parked at a angle (nose up) belly full of air,which I don't understand because I have run out twice before and just added 20 let done the priming thing and of I went,but not this time lesson learnt (dear) but could've been worse. Just got to go and pickup. Thanks for the advise people.
    Thanks Kero
    Jan 2017
    Geraldton WA
    Quote Originally Posted by kero View Post
    Thanks Kero
    How come you run out of fuel so often, Is your fuel gauge broken?
    4.6m Quintrex boat
