Results 1 to 9 of 9
Thread: Load sharing single beam mount suspension
    May 2003
    On The Road
    Probably not its trade name
    I gather this is a simplicity setup,,
    Anyone know how the leaf pack is attached to the centre beam?
    I am having a problem working out just how this shares the load....
    Western Victoria
    That's similar to what is under the Haulmark PT2-2
    May 2009
    It should fix at the centre of the leaf pack and have flexible mount, then it will share the load via the see saw action like a walking beam i.e grader/ moxy.
    Redirect Notice
    May 2003
    On The Road
    Thats what i couldnt figure out,, unless the leaf pack pivots----
    so how do you make a leaf pack pivot? the normal ubolt wont work,,,,
    Western Victoria
    On the Haulmark, the trailer frame pivots around the springs (i.e. the spring pack pivots). They are difficult to manoeuvre by hand as all four wheels are always in contact with the ground no matter how much you tilt the trailer.
    Western Victoria
    May 2009
    This is pivot block
    And installed
    May 2003
    On The Road
    Thanks Fitzy
    so the ends have to be some form of captive slipper?
    not just simplicity, but it looks like it offers better ground clearance and less stuff to get hung up
