Yeah may need a reset, i think i read than disconnecting both + and - leads from the battery and touching leads together will clear the faults.
05 HSE v6 270k shortened rods. No history only had for 10k
Air leak at rear. Discovered hose out of compressor had a hole. Fixed
Compressor is only 2 years old. Win
No leak but after starting car. Fault comes back up. Relay is ok.
Have I missed a reset or where to look next?
1976 LR 90 Hybrid GONE
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1980'RRC Build in progress GOING
Disco wrecking 93 & 94
1993 RRC LSE
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
If you do that reset I am pretty sure you have to wait till the car has gone to sleep. You need to wait till the P light has gone out on the dash.
Anyone close by that has a code reader to check and clear the fault ?
Cheers Ean
Hard reset done but no change. Suspension fault and car on bumpstops
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1993 RRC LSE
 Swaggie
						Swaggie
						It may help if you describe what happens from when the engine is started giving an indication of the time intervals between activity.
Car starts no lights on after 15 seconds suspension fault comes on. Pump doesn’t appear to start
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1993 RRC LSE
 Swaggie
						Swaggie
						The pump not starting will definitely cause a fault.
Did you remove the pump?
Is the electrical connector at the pump firmly fitted to its mating connector?
Is the 5A suspension system fuse in the engine bay fuse box OK?
Can you determine if the pump relay is operating for the 15 seconds then detect it dropping out?
Thanks Graeme
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1993 RRC LSE
Pump was working but shutting off when first gust of air was released on start up. Didn’t disconnect compressor. Checked underbonnet relay
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1993 RRC LSE
Will check the fuse now. Sounds like relay clicks in. Fully on bump stops now
1985 RRC chev GONE
1997 D1 V8 GONE
1973 RRC Gone
1993 RRC LSE
