Maybe petrol's are different but the gauge on my son's V8 D3 is much better than the D4 and allows a decent range because you can use the whole tank. It's also the same on my TDV6 L405. As well as using much less fuel than my D4 the gauge is accurate and you don't seem get a massive reserve that is unusable.
Maybe the difference is that the 85l in the L405 is actually useable and there is a reserve volume on top of that or that the D4 useable volume is not the actual useable volume. Either way, I need the long range tank on the D4 but the L405 is fine without one, despite the specs saying that both have the same sized tank. I've never managed to get even 70l into the D4 tank at zero km to go and below empty.
				Bob
