Results 1 to 10 of 19
Thread: Am I crazy, it ok you won't offend me
    Peter O Guest
    I am new in this section as I usually ferret around in the Series pages but I have some questions you P38 owners may be able to answer.
    After many years with a 1990 RR classic (I fitted a new 4.6 short motor and used my 3.9 heads and injection) we went to other vehicles and the Classic has been used as a farm truck. Recently I found a P 38 that has sat in a shed (slipped liner) for 4 years and is now for sale.
    Aside from the dead engine and has been converted to coils, the rest of the car is very clean and looks pretty much untouched. Its build date is in 1999 so its running a 4.6 and had gas fitted .
    My question is would it be worth buying and fitting my 4.6 short to the P38. Everything is there from the air suspension except the air bags but the air manifold leaks apparently. Are these cars suitable projects or are the parts still so expensive and difficult to source as to be better left alone and leave the motor in the paddock bashing classic.
    Sep 2010
    The Hills.
    152.79 MB
    I guess it comes down to the asking price for the P38A. However, if that is reasonable then I'd say go for it. What can possibly go wrong?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Peter O Guest
    Quote Originally Posted by johntins View Post
    I was hoping you would tell me As for the asking price I have no idea whats reasonable for a car with a dead engine but he was apparently quoted 5500 for a replacement + fitting and that seems to have bluffed him.
    What sort of $ are involved with doing the 4.6 heads over other stuff to fit my 4.6 short. I can do the work easily enough, its just time, but its finding parts and the electrics that worry me.
    Its recently (km) had injectors done and I would want to get rid of all the LPG crap.
    Crafers West South Australia
    Quote Originally Posted by Peter O View Post
    The car is worth $1K tops if it's otherwise in very good nick. To fit your engine, you need to change the inlet manifold and injection, front timing cover, sump, rocker covers and the camshaft, lifters and timing chain. The heads are the same as yours (maybe an accessory bolt hole or two different) so leave them on the engine. Gaskets would cost you around $100 and the labour would be yours to put in. The only curly question would be if your engine has had the crankshaft sensor mounting destroyed, it is tack welded on I believe. There may be differences between early and late 4.6 blocks too in the crank sensor mounting area.
    Sep 2010
    The Hills.
    152.79 MB
    Sound advice as usual. I might have said $1500 for the car. You can get good(?) ones for $4K if you look. Personally, I'd buy it and put an LS1 in it.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Peter O Guest
    Thanks for the info bee utey that is some of what I needed to know. I have some recollection of the sensor mount but cannot remember what I had to do to fit it to the classic, if anything at all. I will go have a look as I seem to recall it being down the side of the block.
    I thought my 3.9 heads would have had smaller ports and not fitted the inlet manifold
    Oh and he wants way more than 1k
    Sep 2010
    The Hills.
    152.79 MB
    In the immortal words of Darryl Kerrigan, tell him he's dreamin'...
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    I agree a LS1 is an excellent idea, but it's going to cost a wee bit more than an already owned 4.6. An update P38 might indeed be worth $1500, it all depends on what's still working. There are so many unique electronic bits to fail on them I'd be going over it with a fine toothed comb before shelling out the readies. They're so completely different to your ol' low electronic Classic Rangie.
    You don't actually need to do anything to the sensor mount to fit a 4.6 to a Classic, it's in the back flange of the block low down on the passenger side. It's just that the ones I've seen have had the mount removed and plugged with a chunk of alloy for neatness' sake.
    Heads are pretty much identical, 3.9 heads come in two slightly different flavours depending on the year, but early ones can have certain holes drilled and tapped to match the later 3.9 and P38 fittings.
    Kingston, Tassie, OZ.
    99 is it a thor or gems still? Is your 4.6 a gems or thor block. Crank sensors are in different positions
